I’m new to Ubuntu MATE (I installed the 64 bits 16.04 version), and I’m having a problem when shutting down both my laptop and my desktop PC. After customizing the appearance a little bit, I keep getting a message when I try to shut down both my computers.
The message says that this program (at-spi-registryd.desktop) is still running. It doesn’t stop running and when I force the computer to shut down, it takes ages to do it.
I already tried that and it didn’t work. I saw it in some Ubuntu threads from 2009 and 2014. I disabled all the assistive technologies in the startup menu but it kept happening. I even removed them all, but after removing Assistive Technologies, the Change background menu just stopped working. And I’m not using a VM.
I disabled that executable in my laptop and it worked. Thanks for your help, v3xx.
The at-spi2-core folder doesn’t exist in my desktop PC. I uninstalled Orca and Onboard and left Assistive Technologies installed. I disabled all assistive technologies in the startup menu, and I also switched from Cupertino to Redmond in Tweak. The message just disappeared when shutting my desktop PC down.
Thanks for your help, again. I really appreciate it.
I don't know if this might help you, but I think you can run sudo caja in the terminal and then go to
as v3xx said. As running sudo caja opens the file manager as superuser, you can then rename the at-spi-registryd file to disable it. Actually, I just changed the permissions so that it wouldn't be executed as a program, but I think the other solution might work as well.
Yes, just uncheck the box that allows it to be executable. Also gksudo should be used with caja or with any gui app you wish to run with sudo privileges. Run in terminal.
I run many LTSP clients with 64-bit Ubuntu MATE 16.04.6 LTS with all installed upgrades. No PPAs are added to the system.
It became very annoying to see this message on shutdown or reboot:
A program is still running:
Not responding
Waiting for the program to finish. Interrupting the program may cause you to lose work.
[Lock Screen] [Cancel] [Reboot Anyway]
And what is interesting, I have never seen this error on 32-bits of Ubuntu MATE 16.04 LTS. This problem seems to exist only for 64-bit OS.
What is a current state of this problem? Does it related to bug 1605224?
This problem is also present in Linux Mint 20, some 11 years after first being reported in Ubuntu. The file is in a different location, so I fixed it by renaming it thus:
sudo mv /usr/libexec/at-spi2-registryd /usr/libexec/at-spi2-registryd.disabled
Thanks for all the prior replies, which pointed me in the right direction.
There must be some user configuration involved to get this error, because I see no such entries in the system logs related to at-spi-registryd on my UM 24.04 desktop. The last entry I see when shutting down (that matches at-spi is):
Apr 03 21:45:50 host systemd[3153]: at-spi-dbus-bus.service: Consumed 42.826s CPU time.
