Did a new install of Ubuntu Mate 22.04 on a Dell XPS laptop. Looked like everything was working great. Went to add a new user and saw the icon was not present. Added the gnome tools and got that to work. I also noticed that I can't find the icon to changed the login screen... It's not there. Is this a bug that's being fixed? Any easy solution?
Here are some links with explanations about this problem and also some workarounds:
Here is a perfect working solution by reverting to slick-greeter:
Extra background info and some workarounds for if you want to keep using 'Arctica' greeter, in the following thread are several ways to bypass some of the problems:
Hallo out there. I made a new installation of Ubuntu MATE 22.04. All works fine BUT i missing the option to manage users and groups. Is there no other way than to install the gnome-system-tools like Georgie-o said? Has the Mate control center no own GUI or tool? I can't believe that... Or is there something wrong with my installation?
Unfortunately, as far as I can tell, that is correct: in Ubuntu MATE 22.04 ("Jammy Jellyfish"), if you want a GUI Tool to manage users and groups, you have to install gnome-system-tools. In Ubuntu MATE 22.10 ("Kinetic Kudu") there's a new tool called "User Manager" that replaces the gnome-system-tools that had been removed from Ubuntu MATE 22.04
A new utility, User Manager, has been added to complement the suite of MATE tools. User Manager replaces the aginggnome-system-toolswhich was removed from Ubuntu MATE in the 22.04 release and allows you to add/modify/remove user accounts. It also includes the ability to define which users are Administrators, enable/disable auto-login, set profile images and manage group memberships.
MATE User Manager
Â
There's also the following related topic here in the Ubuntu MATE Community discussion forums (topic started on 21st April 2022 by @JokerGermany):
