Make Top Right Panel in Mutiny more like Unity?
I noticed that Mate 17.10 Mutiny has a slightly different arrangement of menus/icons to good ol' Unity. I kept hitting the calendar instead of the shutdown menu.
I suggest that the Calendar & the Shutdown menu be swapped around to be like Unity as this is what's being emulated :slight_smile:
There is a technical reason why it’s like this (for now anyway) – The clock is actually a MATE applet, and everything else to the left is an indicator.
Apparently the clock is a bit more difficult to add MATE support due to having tight integrations with Unity. :slight_frown:
Actually adding MATE support is easy. The problem is the indicator-datetime applet is deeply integrated with Unity and GNOME. It is a big task and a new project team in Debian has been formed to tackle making Indicators desktop and distro agnostic.
Would something like this work better as a Mutiny default in the meantime (I used 'separators' to define the areas in the panel but they're not strictly necessary)?
Can you link me to that project?
I found this talk about it by Mike Gabriel.
Thank you. Nice to see one of the best concepts from Unity being carried on and improved.
For now, you could actually take out the MATE clock applet and install indicator-datetime, trying to pull as little of Unity/GNOME as possible:
sudo apt install indicator-datetime --no-install-recommends
Then add its executable to Start-up Applications:
/usr/lib/x86_64-linux-gnu/indicator-datetime/indicator-datetime-service
It works OK and puts itself to the left of the power button like Unity, except that as it’s not integrated to MATE, you’ll need to dig in dconf-editor to modify settings (show seconds, day of week, etc)
