Hello everyone I’m using Ubuntu Mate 16.04 is there anyway to make the folders bigger I did not see anything that may allow me to in large them. Thanks so much
Open Caja (your home folder) > Edit > Preferences and change the 3 boxes to suit your needs:
For further help with the Mate desktop, see this section "Mate desktop guides here:" in the beginners guide right down at the bottom!:
I try this but it does not enlarge the folder with in my files
Ctrl and +
or
Ctrl and -
should work
I’ll give it a try
Thanks
Will this keep the folders larger if I use this method or do I have to do this each time I open the folders and use these key commands
Thanks
Caja will remember the zoom level for each individual folder.
