Mate Compositor quirks - Grey screen and Tearing
Hi All, I noticed when I use any of the Marco (Picom) compositors that upon login between entering my password and getting to the desktop the screen turns grey for a couple of seconds then renders the desktop and wallpaper is this expected behavior?
I'm trying different compositors because if I select "none" or "built-in" I eventually while moving a window get really bad screen tearing then the millions of windows with in windows spiral glitch. Anyone have any advice on either issue? Thanks in advance!
Hi Torkama, welcome to the community :slight_smile:
No, it is not expected behaviour, I've never even seen it before.
OTOH, almost none of my computers have nVidia hardware and I don't run proprietary drivers.
So I am not sure if it is an isolated incident or not.
Maybe you can give us some info on the hardware that you use:
Open a terminal and type: inxi -CGM
Copy and paste the answer here (then select the pasted text and click on the </> symbol to make it a bit more readable.)
Machine:
  Type: Laptop System: Notebook product: NS50_70MU v: Applicable
    serial: <superuser required>
  Mobo: Notebook model: NS50_70MU v: Applicable
    serial: <superuser required> UEFI: INSYDE v: 1.07.09LWL date: 05/01/2021
CPU:
  Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    cache: L2: 5 MiB
  Speed (MHz): avg: 735 min/max: 400/2401 cores: 1: 556 2: 734 3: 568
    4: 785 5: 667 6: 1004 7: 475 8: 1097
Graphics:
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
  Device-2: Chicony USB2.0 Camera type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
    unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.0.5
I copied the INXI output, its a standard Clevo Laptop NS50_MU with Intel Integrated Graphics.
Hi Torkamata,
My apologies, I misread some of your question, so I'll try to answer it again:
The screen turning grey for a moment is unusual but not worrysome.
The fact that it takes several seconds is rather a bit on the slow side.
This is mostly dependent on the speed of the (3D) initialisation of the GPU.
The slowness is caused by either a bug/misconfig in the driver or partly failing hardware .
'no compositor' or 'built-in' should always work.
So if it (compositing) works for you despite the few seconds greyscreen: so much the better
but this behaviour is , nevertheless, a serious issue which should be addressed.
Check if you have the newest kernel. If not: update.
Follow this thread an see if it helps in your case:
Also this terrific post of @ricmarques may be of some help:
If the problem persists:
Best you can do is file a bug on the ubuntu bugtracker:
https://bugs.launchpad.net/ubuntu/+source/linux
After a bug is filed and a fix is committed you only have to wait for a kernel update which then hopefully fixes this issue.
Further: You can explore internet for any open bug on this driver
google for:
Linux i915 bug TigerLake-LP GT2 Iris Xe Graphics
This is all I can offer at the moment.
I hope someone else on this forum chimes in with a bit more info.
my screen has a few moments when its 100% gray as well. Then again, the screen has been acting weird since I installed UM 22.04. The screen goes like:
BIOS screen graphic
Plymouth screen
Booting screen showing aspci errors
Plymouth Screen
Gray screen
Arctica greeter screen
then its fine and I log in
