Mate desktop not appearing after logging in
Every time i log in i always have to run the killall mate-panel command everytime just to start the desktop after a while this gets annoying if anybody can help me with this i would appreciate it.
Hi, @TailsTH723 and welcome to the Ubuntu MATE Community!
I appreciate it ,It really means alot
We need "context" details, which is the report provided by the command:
inxi -ACDMNSG
Once you have posted the report, make sure to have "```" on a line by itself, before and after the text you pasted.
The more expert users in our Community might be able to offer up something more direct or simple. However, ...
Not sure, but maybe reviewing this earlier discussion, where there is mention of a "race condition" during boot that could be impacting the "sanity" or your DM might give you some insights.
Beyond that, if you want to dig in, I suggest you review this earlier posting where I outlined the use of some commands to get a detailed view of the sequence that is occurring during your systemd boot process, to see if there might be an "out-of-sequence" condition which is causing your issue.
Have you tried making changes in the Mate Panel then rebooting?
I hope this helps. I remember installing the official amd drivers and that f***ed up my install and i had to remove the drivers since the kernel supports the amd drivers by default because when i put my games in full screen my fps goes down for no reason thats a separate problem from mate.
Not that i know of but installing the offical amd drivers messed with mate panel
I was afraid it would be that way.
See my answer in your other thread: AMD GPU drivers for radeon pro? - #6 by tkn
