HI! ID LIKE TO SUGEST NOT DUPLICATE APT ICONS IN THE PANEL WHEN YOU ARE USING. ITS DESNECESSARY. ONE BUTTON ARE SUFICIENT. MAYBE CAN APPEAR A LIST WITH FIVE OR SIX RESUMES TO CHOICE THE APT. TO BE MORE CLEAR, I UP THE IMAGE WHERE APPEAR TWO FIREFOX AND TWO CAJA IN THE PAINEL. ONE IS THE SHORTCUT AND ANOTHER IS THE APLICATION RUNNING. TKS.
To avoid this, you can right-click on the Firefox icon (the running one) and select “pin to panel”. Then, you can delete the launcher icon.
Yes! I did it before - dragging the apt icon to the panel and blocking moving too. But all the problem related was in ubuntu mate in portuguese using menu options in portuguese ("Adicionar ao painel" - "Remover do painel" - "Bloquear movimentação"). When i used, the english options ("Pin" and Unpin"), like you said, works well. I upped another images to see it.
Hi @cesarcosta.br,
I suspect you may have part of your language packages missing, open Control Centre > Personal > Language Support and run it.
See also:
