I have Ubuntu 16.04 LTS installed with today’s pack of updates.
I burned the DVD with the Mate 16.04.3-desktop-amd64.iso
There doesn’t seem to be a way to tell the BIOS to boot from the DVD. I hear the DVD cdrank and groan at restart/boot, but after a long time, Ubuntu regular appears.
Tried the Mounted version, nothing.
While Ubuntu sees my USB drive, and contents, U refuses to do anything to it. Keep in mind I don’t have a Geekineze translator so all of the language used in the “How to install Mate from a USB”, which is really ‘How to burn a USB’ using an alien language throws the learning curve a spit-ball.
I’d appreciate help with answers to the following:
- Is Mate supposed boot the system and run off the USB/DVD or dos it install over/with/under or around Ubuntu - if not, does one really have to lean the Linux Geekineze to install it, it or is there a Basic basic easy to follow process? I couldn’t find one. (3 days now trying to install Mate)
Sidebar SUGGESTION:
I would assume the goal is to get as many people using Ubuntu as possible. If so, wouldn’t it be better for Ubuntu, and the computing world at large, if it were really easy to install, like any Windoze files, or at least, use newbie-talk?
I know how to drive a car and can change a tire but have no idea how or why or how to bore out a cylinder and adjusting the lifters.
Also, a cross-reference booklet that interprets some of the technical acronyms, phrases, and terminology would help prevent people from looking at this and thinking ‘screw this - I need an safe reliable O/S - not a steep language learning curve’.
Hey - thanks for your help.
I
