Hi there, just installed standard Ubuntu 20.04 LTS but thought I'd try Mate by installing via "apt-get install ubuntu-mate-desktop" rather than a clean install from an ISO.
However, the top taskbar/panel/dock is missing so I can't logout without using terminal or easily access its features including all the installed apps.
On logging into the Mate environment I did come across the error, "could not apply the stored configuration for monitors". So after doing some research, I did come across people suggesting I should delete ...monitors.xml, but after a search (including hidden files) I don't have such a file.
Also tried "mate-panel --replace", but all that did was reboot bottom panel. The top panel was still missing.
Any ideas please?
System:
Kernel: 5.4.0-29-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: MATE 1.24.0 Distro: Ubuntu 20.04 LTS (Focal Fossa)
Machine:
Type: Desktop Mobo: ASUSTeK model: H110M-A/M.2 v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 1802
date: 06/20/2016
CPU:
Topology: Quad Core model: Intel Core i5-6500 bits: 64 type: MCP
arch: Skylake-S rev: 3 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 25599
Speed: 1139 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Graphics:
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.8 driver: i915 resolution: 1280x1024~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.0.4
direct render: Yes
Audio:
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.4.0-29-generic
Network:
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
port: f040 bus ID: 00:1f.6
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 2.98 TiB used: 392.87 GiB (12.9%)
ID-1: /dev/sda vendor: Crucial model: CT275MX300SSD1 size: 256.17 GiB
ID-2: /dev/sdb vendor: Samsung model: HD103SI size: 931.51 GiB
ID-3: /dev/sdc vendor: Western Digital model: WD20EURX-63T0FY0
Partition:
ID-1: / size: 251.15 GiB used: 13.02 GiB (5.2%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 412.58 GiB used: 379.85 GiB (92.1%) fs: ext4
dev: /dev/sdb5
Sensors:
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Info:
Processes: 218 Uptime: 38m Memory: 7.68 GiB used: 3.07 GiB (39.9%)
Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16
inxi: 3.0.38
