I can’t seem to play any videos, all it gives me is:
$ mpv --hwdec=rpi Desktop/...mkv
Playing: Desktop/....mkv
(+) Video --vid=1 (*) (h264)
(+) Audio --aid=1 --alang=jpn (*) (ac3)
(+) Subs --sid=1 (*) (ass)
mmal: mmal_vc_port_enable: failed to enable port vc.ril.video_decode:in:0(H264):ENOMEM
mmal: mmal_port_enable: failed to enable port vc.ril.video_decode:in:0(H264)(0x55e55280) (ENOMEM)
mmal: mmal_port_disable: port vc.ril.video_decode:in:0(H264)(0x55e55280) is not enabled
mmal: mmal_port_disable: port vc.ril.video_decode:out:0(OPQV)(0x55e55590) is not enabled
Could not open codec.
AO: [pulse] 48000Hz stereo 2ch float
Using software decoding.
Using conversion filter.
VO: [rpi] 1920x1080 yuv420p
mmal: mmal_vc_port_enable: failed to enable port vc.ril.video_render:in:0(I420):ENOMEM
mmal: mmal_port_enable: failed to enable port vc.ril.video_render:in:0(I420)(0x6f667770) (ENOMEM)
Could not initialize video chain.
mmal: mmal_port_disable: port vc.ril.video_render:in:0(I420)(0x6f667770) is not enabled
Video: no video
A: 00:00:04 / 00:01:30 (4%)
Any idea?
did you install the Ubuntu codecs pack?, what I’m reading from your printout is it is codec related, have you also tried using a different player?.
sudo apt-get install ubuntu-restricted-extras
I think it's OpenGL related actually, 'cuz Kodi doesn't start either, telling me errors about libEGL.
Wimpy
18 April 2016 18:47
4
What version of Ubuntu MATE?
Do you have drivers installed?:
You can easily check your GPU by opening a terminal (Ctrl + Alt + t) and typing:
lspci
scroll down to the bottom of the list and you will find something like this:
wolfman:
lspci
Uh... I'm on the Rpi3, there is no PCI. This is the Raspberry Subforum.. Or am I wrong here.
Anyway, I tried what the other user said and install the codecs, didn't solve it. I mean mpv uses the ffmpeg library anyway doesn't it.. so theres no need for additional codecs to be installed, as far as I can tell, It's an issue with the MMAL thing of the Pi, the Video hardware decoder or however its handled.
Sorry but I didn’t notice the Raspi part!
Have you tried a different player and is the problem still the same?.
Have you done a full system update?.
I tried Kodi gives me libEGL errors. My system is always up to date. I can’t do a reset tho as I actively use it as a home server.
Do you have "Welcome" installed and have you tried the repair function out?:
Welcome > Software > Fixes:
I’ll have to re-enable the UI I’ll try it later. Unless you know the terminal commands that button does then I can just run those via SSH.
Run the top two commands in this pic:
sudo dpkg --configure -a
Restart after if anything updates!.
Oh so its just dpkg/apt package error fixing, well no, none of my packages have issues. It's something with the VideoCore GPU, MMAL and OpenMAX something arround that, maybe non existant library files or wrong ones or a softlink not being correct (all guessing)
Hi @DeadSix27 ,
try the following command as it may be a case of missing dependencies?, the following command will force any bits & pieces that are/may be missing!:
sudo apt-get update && sudo apt-get dist-upgrade -f
Encountering the same issue with the released Ubuntu Mate 16.04, did install ubuntu-restricted-extras
ffplay -vcodec h264_mmal /srv/player/data/media/571b9c29-530c-4e41-aa42-050eac110004/media/apple-tv-b1-2.mp4
ffplay version 2.8.6-1ubuntu2+rpi1~xenial1.8 Copyright (c) 2003-2016 the FFmpeg developers
built with gcc 5.3.1 (Ubuntu/Linaro 5.3.1-13ubuntu6) 20160407
configuration: --prefix=/usr --extra-version='1ubuntu2+rpi1~xenial1.8' --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-mmal --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264
WARNING: library configuration mismatch
avcodec configuration: --prefix=/usr --extra-version='1ubuntu2+rpi1~xenial1.8' --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-mmal --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-version3 --disable-doc --disable-programs --disable-avdevice --disable-avfilter --disable-avformat --disable-avresample --disable-postproc --disable-swscale --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libvo_aacenc --enable-libvo_amrwbenc
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/srv/player/data/media/571b9c29-530c-4e41-aa42-050eac110004/media/apple-tv-b1-2.mp4':
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
creation_time : 2015-09-22 18:33:35
encoder : Lavf56.1.0
Duration: 00:03:59.83, start: 0.000000, bitrate: 3755 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 3751 kb/s, 30 fps, 30 tbr, 30030 tbn, 60060 tbc (default)
Metadata:
handler_name : VideoHandler
mmal: mmal_vc_port_enable: failed to enable port vc.ril.video_decode:out:0(I420): ENOMEM
mmal: mmal_port_enable: failed to enable port vc.ril.video_decode:out:0(I420)(0x6b206990) (ENOMEM)
mmal: mmal_port_disable: port vc.ril.video_decode:out:0(I420)(0x6b206990) is not enabled
Failed to open file '/srv/player/data/media/571b9c29-530c-4e41-aa42-050eac110004/media/apple-tv-b1-2.mp4' or configure filtergraph
nan : 0.000 fd= 0 aq= 0KB vq= 0KB sq= 0B f=0/0
Any ideas?
Fixed it with gpu_mem=192
in /boot/config.txt
