A rather instense, but straightforward Conky. Me like.
It's time for some circles...
Icons: Numix-circle
launcher: gnome-pie
wallpaper: pawel-czerwinski-_nqApgG-QrY-unsplash
Where did you get that background?
I made it myself
You should upload it, I rather like it
If youj want it,, and don't mind the image being the size of his desktop you could just cut the middle bit out and paste it central to a blank image of equal size with that background colour.
Awesome. Also an easy image to change if one were to dislike the background.
Hi! I like the wall paper. Where is this from? Can I download it from anywhere?
Thanks! Can I use it?
Yes, sure.
I do not claim any copyright
What theme are you using to achieve transparent upper bar?
Hi: I don't remember, but I think all I did was right click on it and adjust transparency. Son took laptop & put another distro on it so not able to go back and check.
Haven't used desktop icons in years, so i thought i'd have a bit of a change.
I had a conky but it was giving me too much grief. (Life's too short)
