My mouse can not use it as I would like
Hello, it goes anywhere. It seems that it is too sensitive in Ubuntu mate. I tried to adjust it in the mouse options, but no change occurs. I tried it on Windows and it works fine. It’s wireless KCL-10 wireless, I can not find the manufacturer on the internet. Somebody could help me. I would be grateful.
what version of UM are you using
maybe this post solves your problem.
Mickey :relaxed:
Hi @rdsparla, If you are running 16.04 I can vouch for this fix...
But the same hardware has no issue with 18.04.
