Need help my Wifi did not work
I am new in Linux that is my first day .But from the start i have problem… My Wifi not work i dont know why .I see other topic here but everyting i do again not work … can some one help and give simple answer for new :smiley:
My laptop HP Model :15-ac128nu
Тhanks!
Hi @Xcess
Please provide the output for the following command typed in a terminal:
sudo lshw -C network
You can open the terminal using the shortcut CTRL+ALT+T
When you enter the command, it will prompt you for your password.
Stars won't be echoed back to you when you type your password: this is normal, just keep typing then press Enter.
Once you have the result of the command, you can copy from the terminal using CTRL+SHIFT+C
Cheers
Also
Have you ran your first update?
Hi again.
Sorry for late reply, i reinstall Linux mate 16.04 for sure i am do someting not wrong and delete all my experiments .I see the beginners guide and install update but again noting happen…
I go this command in a Terminal sudo lshw -C network
*-network UNCLAIMED
       description: Network controller
       product: RTL8723BE PCIe Wireless Network Adapter
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: ioport:2000(size=256) memory:a1200000-a1203fff
  *-network
       description: Ethernet interface
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: enp3s0
       version: 07
       serial: fc:3f:db:b1:9a:9f
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8106e-1_0.0.1 06/29/12 ip=192.168.1.23 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:117 ioport:1000(size=256) memory:a1100000-a1100fff memory:a1000000-a1003fff
What i do next …
Thanks!
Try unloading and reloading the wireless network adapter…
Go to the terminal by using the key sequence:
Ctrl+Alt+T
From the terminal run the following command:
sudo rmmod rtl8723be && modprobe rtl8723be
Hi @Xcess,
have you also tried running the "Additional Drivers Tool" in the Control Centre?:
Hi again.
I try both but noting happen ..
now i see my network adapter but when i try to connection he tell me i am connection but when i go internet browser i no have internet .........
I am in 1 meter from my ruter in same room.
And when i go to "Additional Drivers" i see only one driver for my intel processor.
i no see drivers for my graphic card or other devices ....
I have AMD Radeon M330 1 GB.
Thanks!
@larryb made a small mistake I think.
Try:
sudo rmmod rtl8723be && sudo modprobe rtl8723be
I try that my internet come for 2 min and loses … wifi show me i have internet but when i try to go internet browser no have … HOLY…
My ruter is 1 meter from my laptop but wifi still show me only 2 bars.
How is possible that … that is from linux or from my laptop .
In windows works fine in full bars and i no have problem with him but i dont wanna back to windows 10… please …
Cheers!
Try this:
echo "options rtl8723be fwlps=0" | sudo tee /etc/modprobe.d/rtl8723be.conf
That'll add an option to the driver to disable power savings, then reload the driver using:
sudo modprobe -r rtl8723be
As for the WiFi icon showing wrong strength status my advice is to ignore it for now, it's most likely due to the multitude of active bugs in network-manager et al.
Instead, use the following command to monitor connectivity:
ping -s16 8.8.8.8
If you get ping replies under 10ms consider you have a good connection, and don't bother looking at the icon.
I try you guidance get this error
I ping -s16 8.8.8.8 show me 30-40ms.
Cheers!
Most likely you made an error with the command.
The file /etc/modprobe.d/rtl8723be.conf should only contain the following:
Make sure this is the case using:
sudo pluma /etc/modprobe.d/rtl8723be.conf
When i wrote this command in a Terminal sudo pluma /etc/modprobe.d/rtl8723be.conf
show me this
Now no have error i wrote this command in file options rtl8723be fwlps=0 when use this command in a Terminal sudo pluma /etc/modprobe.d/rtl8723be.conf my
And problem stay when i use Wifi internet is very slow or drop every 2 min ... not from my internet provider.
When i use cable i download with 2 MB/s .. when use Wifi 100 KB/s ..... HOLY..
here i have other one laptop with windows 7 and he no have that problem with Wifi . Cable or Wifi he download with 2 MB/s and no have that problem with drop or lose connection....
Have way to fix it on linux laptop?
Cheers!
Hi, check this. It might be of some help :
" Quite often, the weak signal is a symptom of the antenna wire being connected to connection #1 on the card when the default driver is expecting to see the signal at connection #2. Of course, you could open the laptop and switch the wire or you could install a newer driver that permits antenna selection at the driver level. "
The quoted text and the solution for this can be found at the following link :
http://askubuntu.com/questions/645220/unable-to-connect-wifi-ubuntu-14-04-lts-hp-pavilion-network-driver-rtl8723be/729660#729660
