I have just fresh installed Ubuntu MATE 16.04 on an Intel NUC5PPYH which has the latest BIOS installed.
Everything works fine except I cannot get any sound through HDMI. Video through HDMI works fine.
Under “Sound Preferences” the only device shown for sound output is “Built-in Analog Stereo”. Installing pavucontrol and alsamixer similarly do not show a HDMI device for audio output.
I then installed Ubuntu 16.04 and sound through HDMI works perfectly.
I really don’t know what else to do! Perhaps I should install MATE desktop on Ubuntu but that’s probably not going to be as well integrated as Ubuntu MATE.
Hi Wolfman,
Unfortunately there is no HDMI device shown to mark. The only device which appears is “Built-in Analog Stereo”. I have checked this many times, rebooted many times, plugged HDMI cable in and out many times. No HDMI device ever appears.
Greggy.
SOLVED
In the Hardware Tab in the field “choose a device to configure” that device will only say HDMI, in that field and also under the “output” tab, if its profile is also set to HDMI under “Settings for the Selected Device”. This is
different to how it’s presented in Ubuntu Unity which I think must have caused me to think that the device was not shown.
Serves me right for not exploring all the settings properly. Thanks for suggesting to look at both tabs in more detail. This simple oversight cost me several hours!
