I updated my UM 21.10 to 22.04 and all works great! Thank you for this masterpiece!
Marco especially seems enhanced. I no more have screen disturbances at Libre Office like "scratched" words.
But I miss the new "weather" applet.
Is there any chance to get it without full new install?
I added it by right-mouse-click on the mate-panel -> add to panel -> weather report.
I happened to do a fresh install so that is a bit different from your situation.
If you don't see the "weather report" in the "add to panel" list, you might want to check if these files are installed:
Different from 20.04:
20.04 had the weather and the clock in one applet: the clock applet
22.04 has the weather and the clock as two separate applets
this might be the reason that your weather applet "disappeared" from panel.
Hi tkn,
until now I am using the old weather report and I see no possibility to add the new one. I have the "weather report" in the "add to panel" list, but the old one.
The search command gave no answer but a check at synaptic shows me all the files you mentioned. Weird, isn't it?
Which new weather applet in UM 22.04 are you referring to? UM 22.04 has the GNOME Weather application preinstalled, but it is not an applet, it is a simple window application.
It is the new wheather applet I wanted but still have the old one.
I also installed Gnome weather 42.0 which did not work at UM 21.10.
But it is not essential. I found Meteo and am happy with it!
Thank you for your assistance!
tatanka
