I can only connect via ethernet and have no wifi connection. I’m wondering if it’s hardware locked? Any tips?
Network controller: MEDIATEK Corp. MT7630e 802.11bgn Wireless Network Adapter
Does this help you?
Unfortunately not. After following the instructions step-by-step I get a “no key” message.
If you are using Ubuntu Mate 17.04 see the following link.
https://ubuntu-mate.community/t/wifi-issue-in-17-04/12622/15?u=steven
Doesn’t help man. I’m not even getting a Wifi signal…
This discussion sounds similar to your situation
