Hi, I'm using Mate 1.24.1 with Debian Buster.
I activated grouping of windows tabs in the taskbar. The problem I have is that the order of the grouped tabs is changing all the time.
For instance, I have 19 instanes of Firefox. I click on the grouped tab, and the list deploys, and I select and work with one.
Then I can go to another application, like caja. When I click on the grouped Firefox again, the list is in a different order, and I have to search the window I'm looking for every time.
The same applies to new instances of Firefox, I'd expect them to be at the top or bottom, but they are placed anywhere.
I've worked with other desktop environments, like KDE, where the order is kept, so I can remember the approximate position on the list, and new instances are added at the bottom.
Is there any way to order this list, by creation date for instance?
Regards.
