Hello, I have an issue with the Compiz Window Manager.
When I boot up my desktop, I cannot click mate-panel. Both right and left clicks do not work.
In order to work around this I use Alt + F1 to bring up the Applications menu. From there I can navigate the menu and launch a terminal. I use ps aux | grep panel to find the process ID of mate-panel and then use kill <id> to kill mate-panel. At this point mate-panel will relaunch itself and I can use the desktop as normal.
Currently I am using Compiz due to an issue I was having with Macro. That issue was logged here.
Is there any logs I could provide to help diagnose this issue?
The issue occurred again today. So the Workarounds in CCSM doesn’t solve the issue.
I’ll try the rc.local solution referenced in the thread @lepa22 provided. Though, the solutions there don’t really answer any questions.
Why is mate-panel unresponsive with compiz? This really shouldn’t be happening and force killing it after boot has completed is a hack. Are there no logs for either compiz or mate-panel that will help look into what is causing this issue?
