The text in my PDFs is quite fuzzy and hard to read, and the thinner the text the worse it gets. This does not appear to be as much of a problem in other applications and I've uploaded a browser page (left) and a pdf (right) to show the difference. This makes me suspect it's something specific to the way PDFs are being displayed. I have checked using different PDF viewers and the problem is the same.
Font settings: Subpixel smoothing (LCDs)
Ubuntu Mate 16.10
Mate Desktop environment: 1.16.0
Any thoughts would be appreciated.
Bonjour, je pense que la compression des pdf est trop importante et donc les pdf apparaissent plus ou moins flou.
cordialement
Hello, I think the compression of the pdf is too important and therefore the pdf appear more or less blur.
cordially
Hallo
We need more to go on.
- How were the pdf files produced (software)?
- What settings were used?
- Could you list the “properties” of some examples?
- Are they images converted to pdf or text converted to pdf (and OCR’d)?
- Which pdf readers have you tried?
The more information you can provide the greater the chance that one of us may be able to help.
This sounds like a “font rendering” problem.
- try opening the pdf files in firefox. Is there any improvement?
- what “graphics acceleration” features have you active (compiz or the like)? What happens when you turn them off (and re-boot)?
- how does you computer handle graphics (intel-on-board or grapics card)?
- if you have a graphics card, have you installed the “proprietary drivers”? If not try that, what happens?
I’m more or less out of ideas here, can anyone else help?
P.S.
Did you have these problems when using Ubuntu-Mate 16.04.2 ?
Hallo
Have you seen this:
Your problem may possibly be at this level - it might be worth trying 17.04 (I've no information to suggest that this will help though).
Is replacing the graphics card an option?
I hope you manage to solve your problem.
Thanks for checking back
I didn’t know about that but it does help explain why I couldn’t find the proprietary drivers for my card!
To-date I’ve resorted to enlarging PDFs to get around the poor text display and will try upgrading to the new version.
Did you have any idea why Firefox would display text in PDFs better than the system PDF viewers?
It’s quite a nice graphics card so I’d rather not!
