Just loaded Ubuntu MATE onto a pi-top. It works far better than the default pi-topOS, but it lacks battery information. Is it possible to get that somehow?
Pretty great otherwise!
I don’t know what pi-top is. You can try installing acpi and get it thru CLI.
You can add battery monitor to your panel by r-clicking on a blank spot on the panel and going to Add to Panel.
If you want to use the terminal monitor
Ctrl + Alt + t
enter:
upower -d
And the are the dconf settings located in dconf editor>org>mate>power-manager.
Thanks! I’ll try that when next I have the time to install again. The SD card I was working with got fried somehow when I tried to apply software updates.
x86 problem?
malwaredpc, a pi-top is a raspberry pi laptop. No cable spaghetti on the table, and you get ten hours of battery life.
Thanx You can try with Gparted to give it a new partition table and it may work again.
It feels easier to just put new images on three or four SD cards and swap them in every time I kill one.
To my earlier mistake applying software updates, it turns out I was supposed to type ‘sudo rpi-update’ instead of a general update.
I tried the upower -d command as suggeted and got nothing. The operating system is recognizing no battery and thinks I’m plugged into the wall. That is probably to be expected since the pi-top battery is a pretty custom thing.
