pi-topCEED and pi-topSPEAKER help required
Hi
I have Pi 3 running Ubuntu Mate 16.04 and I have it plugged into a plugged into a pi-topCEED screen and I have the pi-topSPEAKER attached also.
The problem I have is the USB park of the CEED hub doesn’t work and also the SPEAKERS don’t work.
The pi-topOS that came with the screen does enable for it to work, but I really want to stay with Ubuntu instead.
Has anyone managed to get this fully working?
Thanks
Hi @mattwhaley,
does this help?:
https://github.com/rricharz/pi-top-install/blob/master/speaker.txt
See also (in case you want to ask a question there):
http://support.pi-top.com/support/login/
