Hi, I am trying to use plank, but after a reboot the dock disappear, I need to start it again from the app menu. At least I don’t loose my configuration. Any help? Thanks!
You may need to add it to your start up applications.
I use Plank configured at the bottom of my screen. I deleted the bottom MATE panel.
Thanks! I will try that
And here is how to do it...
