Hi @yannick,
I’m not really sure where to go from here as I don’t have one myself!, is it part of a network?:
Hi @yannick,
Hi Wolfman, I try another way
-1-
Boot on a live usb ubuntu 16.04 ( standard - unity ) , my printer is well detected as a clx-3300, its deviceid ( in lsusb) is stable and i can print all documents i want.
-2-
Boot on a live usb ubuntu 16.04 Mate , my printer is not detected and deviceid change very often ( in lsusb command)
I cannot print.
What is so different in Mate compared to unity in usb printer management ?
Yannick
Please use code tags. I have edited the above.
Thank you
Hi @yannick,
the following terminal command (Ctrl + Alt + t) will make sure that any missing dependencies get installed if there are any missing!:
sudo apt-get update && sudo apt-get dist-upgrade -f
Restart after running the command if anything updates at all and MAKE SURE YOUR PRINTER IS SWITCHED ON AND ACTIVE!.
I don’t know why it works under Unity and not Ubuntu Mate sorry?. ![]()
After many tries without any success, i replaces ubuntu mate by unity , that i don’t like but it works with my mfp clx-3305. I regret mate interface … may be i will come back in a future if problem is resolved
Thanks a lot for your efforts . Yannick
Hi @yannick,
you can install all the Mate stuff on top of unity with one command!:
sudo apt-get install mate-desktop-environment-core mate-desktop-environment-extras ubuntu-mate-welcome
and then click on “Subscribe to Welcome updates” after starting Welcome
Bonjour,
I discovered Ubuntu Mate some months ago and it is the Linux distrib I prefer !
But I get the same issues as Yannick with my Samsung ML-2240 printer, and I tried many of the tricks that I found in this topic, without success.
Xubuntu is installed on the second HD of my computer. Both are Linux 16.04.
I really wonder why, with the same printer on the same PC, Xubuntu prints well everytime and Ubuntu Mate does not.
With Mate, the printer “enabled” unchecks some seconds after I checked it.
I may use the following tip, that does not always work: I press the printer button one time (short press) just before checking “enable” and immediately after, then generally it print… but sometimes not.
I hope the Ubuntu Mate programmers will find what is wrong, for UM is an excellent distro !
Michel
Hi !
Just some words to say my Samsung ML-2240 works well after something I tried. I found this web page about installing the Samsung driver.
First, I uninstalled all the suld files I had installed from chemnet ppa (maybe there are very good drivers for some printers but it did not really help for my ML-2240).
I had tried the official samsung Linux Driver, too, and I uninstalled it (my printer staid plugged… until I tried to print)
The site where I found the procedure is this one:
http://downloadlinux.net/2016/03/01/how-to-get-install-samsung-ml-2240-printer-scanner-drivers-for-ubuntu-16-04-xenial-lts-linux/
The good thing to do was perhaps to copy the installation file in /tmp, then follow the doc.
Best regards,
Michel
Guys,
I’m experiencing the same issue with a Samsung printer ML-1665. I have some knowledge with linux and I was able to trace the problem a little futher. I believe there is no bug in drivers (libgutenprint or those from samsung). The problem seems to be in a deeper layer (libusb or some other usb component or even with the kernel).
It is instructive to monitor the logs during when connect the printer. Try run
sudo tail -f /var/log/syslog
Then connect the printer to the USB port. I my case, it is clear that the printer is discovered correctly, but then after few seconds it is disconnect, no matter what it is being done. The block below was pasted from my syslog.
> Nov 13 14:26:39 salvia kernel: [ 402.469272] usblp1: removed
> Nov 13 14:26:39 salvia udev-configure-printer[2940]: remove /devices/pci0000:00/0000:00:14.0/usb1/1-4
> Nov 13 14:26:39 salvia kernel: [ 402.635090] usb 1-4: new full-speed USB device number 9 using xhci_hcd
> Nov 13 14:26:40 salvia kernel: [ 402.821168] usb 1-4: New USB device found, idVendor=04e8, idProduct=3301
> Nov 13 14:26:40 salvia kernel: [ 402.821176] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
> Nov 13 14:26:40 salvia kernel: [ 402.821181] usb 1-4: Product: ML-1660 Series
> Nov 13 14:26:40 salvia kernel: [ 402.821185] usb 1-4: Manufacturer: Samsung Electronics Co., Ltd.
> Nov 13 14:26:40 salvia kernel: [ 402.821188] usb 1-4: SerialNumber: Z5ASBDAZ809914N.
> Nov 13 14:26:40 salvia kernel: [ 402.823273] usblp 1-4:1.0: usblp1: USB Bidirectional printer dev 9 if 0 alt 0 proto 2 vid 0x04E8 pid 0x3301
> Nov 13 14:26:40 salvia mtp-probe: checking bus 1, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4"
> Nov 13 14:26:40 salvia mtp-probe: bus: 1, device: 9 was not an MTP device
> Nov 13 14:26:40 salvia udev-configure-printer[2903]: no corresponding CUPS device found
> Nov 13 14:26:40 salvia systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb1-1\x2d4).
> Nov 13 14:26:40 salvia systemd[1]: printer.target: Unit not needed anymore. Stopping.
> Nov 13 14:26:40 salvia systemd[1]: Stopped target Printer.
> Nov 13 14:26:40 salvia systemd[1]: Reached target Printer.
> Nov 13 14:26:40 salvia systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb1-1\x2d4)...
> Nov 13 14:26:40 salvia udev-configure-printer[2960]: add /devices/pci0000:00/0000:00:14.0/usb1/1-4
> Nov 13 14:26:40 salvia udev-configure-printer[2960]: device devpath is /devices/pci0000:00/0000:00:14.0/usb1/1-4
> Nov 13 14:26:40 salvia udev-configure-printer[2960]: MFG:Samsung MDL:ML-1660 Series SERN:- serial:Z5ASBDAZ809914N.
> Nov 13 14:26:45 salvia kernel: [ 408.655373] usb 1-4: reset full-speed USB device number 9 using xhci_hcd
> Nov 13 14:26:46 salvia kernel: [ 408.841039] usb 1-4: USB disconnect, device number 9
> Nov 13 14:26:46 salvia kernel: [ 408.841488] usblp1: removed
So far, I have tried to install a kernel from ubuntu 14.04, without success. Perhaps this is an indication that the problem is in usb components instead of in the kernel itself, but I am not 100% sure of that yet.
As someone has commented that her/his printer is working with other flavor of ubuntu 16.04, I will try to install the kernel of that particular flavor to test, as well as compare the versions of the usb components.
Good luck to all.
I’ve got the same problem on Ubuntu 16.04 with a HP printer (HP Envy 4500). I need to go to printers to re activate it every time after printer goes to sleep.
Here is my sudo tail -f /var/log/syslog :
`Jan 26 20:50:35 christine-G43M01 packagekitd[22272]: (packagekitd:22272): GLib-CRITICAL **: Source ID 9 was not found when attempting to remove it
Jan 26 20:51:53 christine-G43M01 dbus[833]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service'
Jan 26 20:51:53 christine-G43M01 systemd[1]: Starting PackageKit Daemon...
Jan 26 20:51:53 christine-G43M01 PackageKit: daemon start
Jan 26 20:51:53 christine-G43M01 dbus[833]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jan 26 20:51:53 christine-G43M01 systemd[1]: Started PackageKit Daemon.
Jan 26 20:55:48 christine-G43M01 AptDaemon: INFO: Quitting due to inactivity
Jan 26 20:55:48 christine-G43M01 AptDaemon: INFO: Quitting was requested
Jan 26 20:55:48 christine-G43M01 org.debian.apt[833]: 20:55:48 AptDaemon [INFO]: Quitting due to inactivity
Jan 26 20:55:48 christine-G43M01 org.debian.apt[833]: 20:55:48 AptDaemon [INFO]: Quitting was requested
Jan 26 20:58:18 christine-G43M01 kernel: [264140.272061] usb 2-2: new high-speed USB device number 8 using ehci-pci
Jan 26 20:58:18 christine-G43M01 kernel: [264140.404933] usb 2-2: New USB device found, idVendor=03f0, idProduct=c511
Jan 26 20:58:18 christine-G43M01 kernel: [264140.404939] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 26 20:58:18 christine-G43M01 kernel: [264140.404942] usb 2-2: Product: ENVY 4500 series
Jan 26 20:58:18 christine-G43M01 kernel: [264140.404944] usb 2-2: Manufacturer: HP
Jan 26 20:58:18 christine-G43M01 kernel: [264140.404946] usb 2-2: SerialNumber: CN5783307105X4
Jan 26 20:58:18 christine-G43M01 kernel: [264140.405752] usblp 2-2:1.1: usblp0: USB Bidirectional printer dev 8 if 1 alt 0 proto 2 vid 0x03F0 pid 0xC511
Jan 26 20:58:18 christine-G43M01 root: loading HP Device 002 008
Jan 26 20:58:21 christine-G43M01 python3: io/hpmud/musb.c 2183: [23862] hpmud_make_usb_uri() bus=002 dev=008
Jan 26 20:58:21 christine-G43M01 python3: io/hpmud/musb.c 2281: hpmud_make_usb_uri() uri=hp:/usb/ENVY_4500_series?serial=CN5783307105X4 bytes_read=46
Jan 26 20:58:22 christine-G43M01 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:1d.7-usb2-2\x2d2)...
Jan 26 20:58:22 christine-G43M01 udev-configure-printer[23873]: add /devices/pci0000:00/0000:00:1d.7/usb2/2-2
Jan 26 20:58:22 christine-G43M01 systemd[1]: udev-configure-printer@-devices-pci0000:00-0000:00:1d.7-usb2-2\x2d2.service: Control process exited, code=exited status=1
Jan 26 20:58:22 christine-G43M01 udev-configure-printer[23873]: device devpath is /devices/pci0000:00/0000:00:1d.7/usb2/2-2
Jan 26 20:58:22 christine-G43M01 systemd[1]: Failed to start Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:1d.7-usb2-2\x2d2).
Jan 26 20:58:22 christine-G43M01 udev-configure-printer[23873]: Device already handled
Jan 26 20:58:22 christine-G43M01 systemd[1]: udev-configure-printer@-devices-pci0000:00-0000:00:1d.7-usb2-2\x2d2.service: Unit entered failed state.
Jan 26 20:58:23 christine-G43M01 systemd[1]: udev-configure-printer@-devices-pci0000:00-0000:00:1d.7-usb2-2\x2d2.service: Failed with result 'exit-code'.
Jan 26 20:58:31 christine-G43M01 colord-sane: io/hpmud/musb.c 2095: Invalid usb_open: Permission denied
Jan 26 20:58:31 christine-G43M01 colord-sane: message repeated 3 times: [ io/hpmud/musb.c 2095: Invalid usb_open: Permission denied]
Jan 26 20:58:31 christine-G43M01 colord-sane: io/hpmud/pp.c 627: unable to read device-id ret=-1
Jan 26 20:58:38 christine-G43M01 PackageKit: daemon quit
Jan 26 20:58:38 christine-G43M01 packagekitd[23514]: (packagekitd:23514): GLib-CRITICAL **: Source ID 9 was not found when attempting to remove it
Guys I think I found the cause. When I booted into a Live System my printer worked fine (Samsung ML-1640), also on a fresh installed system (16.04, 16.10, 17.04 Beta). I’ve made a postinstall script a while ago for the installation of some software and themes and after running it my printer get randomly paused. So I decided to reinstall Ubuntu and then install every single program one after another with reboots between and tried to print something.
To cut a long story short, it seems to be tlp. Have you guys installed it? If so try to remove it with:
sudo apt purge tlp tlp-rdw
and reboot. After that your printer should work as expected, at least mine is. I hope this solves the issue for you, it was really annoying that the printer wasn’t working as he should.
You can still use tlp but you have to deactivate USB-autosuspend or add your printer ID to the blacklist. To add the printer ID do the following:
http://linrunner.de/en/tlp/docs/tlp-configuration.html#usb
I filed a bug report here
@mrprobot, thanks for your investigation.
I don't know why I have the weirdest déjà-vu about this thread.
Edit: maybe because of that:
Thank you Mrprobot.
I can confirm that from a clean install of Ubuntu Mate 16.04, followed by installing the Samsung Unified Linux Drivers, and then blacklisting my Samsung printer in tlp, the printer pausing has been resolved.
Thank You, that seemed to do the trick for me, too! (I did not even have to reboot, just ran “sudo tlp usb” in a terminal…)
thank you so much! I searched for weeks and noone found the solution but you. I am so happy
