Problem encountered in panel when loading brisk menu
Whenever I boot my computer this error prompt and it says to delete or don't delete brisk menu, this is really annoying in my ubuntu mate 20.04.
reinstall applet works for me:
sudo apt-get remove --purge mate-applet-brisk-menu
sudo apt-get install mate-applet-brisk-menu
Cheers
No still it didn't worked for me but thanks for the help.
Ok, try now:
sudo apt install --reinstall mate-applet-brisk-menu
sudo service lightdm restart
new session brings: "The panel encountered a problem while loading "BriskMenuFactory::BriskMenu".
Hi David,
You probably could use the info here (thanks to @ricmarques) :
