Hi!
I just installed UbuntuMate on my Raspberry Pi 2 B!.. The problem is, it shows that I have a total disk of 3 gb, while I have 16GB on my sdcard. I’m very new to linux and mate… Can someone help me?
You need to just resize the partition on the sd card. use a program called gparted
(i cant remember if gparted installed by default)
How to install gparted
- Press F12 to open Tilda
- Type
sudo apt-get install gparted -y
- Press enter
- type your password
- Press enter
- Press F12 to close tilda
Load GParted
Goto System > Administration > GParted
enter your password.
Have a look at this post to get some idea how to use gparted to resize the partition.
https://ubuntu-mate.community/t/gparted-partition-guide-for-linux-and-windows-users/797
also have a look at this http://gparted.org/display-doc.php?name=help-manual#gparted-resize-partition
