alejc
5 March 2018 16:01
1
MATE Desktop Environment 1.16.2
Ubuntu Mate 16.04.3 LTS x64
sudo apt-add-repository ppa:ubuntu-mate-dev/xenial-mate -y
sudo apt-get update
sudo apt-get full-upgrade
after reboot and update again:
mate-dock-applet: Depends: gir1.2-keybinder-0.0 but is not installable
Thanks
Hi alejc,
try changing your software sources download location and updating again.
These are my own setting preferences, use at your own risk!.
AN IMPORTANT NOTE FOR LINUX BEGINNERS. WHEN YOU ARE IN RECOVERY MODE, THE KEYBOARD DEFAULTS TO US ENGLISH, IF YOU HAVE ANY OTHER LANGUAGE KEYBOARD OTHER THAN US ENGLISH, WHEN YOU TYPE "Y" (FOR "YES"), IT MIGHT SHOW UP AS A DIFFERENT LETTER, ON MY KEYBOARD I MUST PRESS THE "Z" KEY WHICH EQUATES TO "Y" AS I HAVE A GERMAN KEYBOARD, JUST PRESS "BACKSPACE" AND HIT A DIFFERENT KEY UNTIL YOU SEE THE "Y" SHOW UP!.
Click on "Subscribe…
alejc
6 March 2018 14:07
3
Solved, but in another way:
mate-dock-applet of the ppa repository: ubuntu-mate-dev (MATE Desktop Environment 1.16.2) comes into conflict with mate-dock-applet original version included in Ubuntu Mate 16.04.4 LTS MATE Desktop Environment). Then the conflicting version of mate-dock-applet is uninstalled
thanks a lot
