Hi everybody!
I am searching (with no success…) configuration file for QT Ambiant Theme.
Anyone can suggest me the right place?
Thank you!
Hi Charlie,
Open Caja > File system > usr > share > themes and look around in there, be careful what you do and you will need to open the files as "root" (administrator).
Hi Wolfman,
AFAIK that theme folder is just for GTK themes.
I need the themes for QT. (E.g. : program skin like VLC or VirtualBox).
Thanks
Hi Charlie,
sorry!, I thought they would be there too.
I found this which might interest you as I cannot find out where the damn things are kept, this is an older post from OMG Ubuntu so please be aware of that!:
Hi Wolfman,
thank you for sharing but I had already read that article and it expect that you use Adwaita theme both for GTK and QT and I would like to use Ambiant in my Distro. I made it about GTK theme (using those file you correctly pointed) but when I use VLC or Virtualbox they are grey (default QT theme) on black and it looks pretty horrible
Hope that anyone else could help me.
Hi everybody!
Hi Charlie,
it might be related to your graphics card?, what GPU do you have?, see the following which might also help you. ![]()
