Hi everyone
When I run sudo fdisk I see for patritions:
/dev/mmcblk0
/dev/mmcblk2
I then ran:
sudo fdisk /dev/mmcblk0
sudo fdisk /dev/mmcblk2
and then
sudo resize2fs /dev/mmcblk0p2
then wrote it and exited. Upon restart, it did not startup.
Can someone shed some light on what I did wrong?
Thank you -Ryan
Re-size file system
There are no utilities included for automatic file system re-sizing. However, it’s not hard to do manually. Once booted:
Delete the second partition (d, 2), then re-create it using the defaults (n, p, 2, enter, enter), then write and exit (w). Reboot the system, then:
