Hey, everyone, I want to remote desktop my RPI 3 with Ubuntu Mate 16.04 on it. I want to use vnc ,but the thing is when I go to raspi-config to enable vnc it is not there. I got it to work on raspbian because it had that option to enable vnc. Do I need to install some packages for that option to be on raspi-config?
I am using it with Mate.
You need to download the .deb from the webpage:
https://www.realvnc.com/en/connect/download/vnc/raspberrypi/
Then to start it:
https://www.realvnc.com/en/connect/docs/unix-start-stop.html#unix-start-stop
I want to enable VNC on every boot so I have to run this command.
sudo systemctl enable vncserver-x11-serviced.service
I did it and it gave me this.
Failed to execute operation: No such file or directory
I downloaded VNC too already.
Why not try teamviewer for armhf?ww
I have used vnc for raspbian and I liked it. I just don’t know why ubuntu mate does not have the option to enable it.
I think I might just use xrdp instead.
Weird,
I have it running without issues. If I run the command: sudo systemctl enable vncserver-x11-serviced.service, I do not get the error you get. Maybe try to re-install it?
