Sceptre E205W-16003R driver
Hi. I've gone back to 20.04 and my desktop won't recognize the monitor. I've gone to Sceptre's website, but couldn't find the driver for my monitor; Sceptre E205W-16003R. I'm also having Nvidia driver issues--I haven't done that much on this front, but have the Geforce GTX 1650. Thanks.
Hi Anthony :slight_smile:
Let's tackle the monitor-driver issue first:
This may come as a surprise but monitor drivers do not actually exist.
That may sound a bit weird but let me explain:
Monitor drivers are not drivers at all so what is it then ?
Monitor "drivers" are at most a bundle of software that contains:
  1. ICC color profiles (only used by one or two applications like photoshop)
  2. workarounds for EDID firmware bugs
    (check that link for some backgound info about it)
So "monitor drivers" don't do any driver work at all.
It is a misnomer invented by display manufacturers to hide the ugly truth of the bugs in their product. Those so called "monitordrivers" are also MS-windows only because displaymanufacturers are flipping the bird to anything non-windows.
All is lost then ?
No, you definitely NOT need them to get a functioning monitor.
Everything comes down to your NVidia issues. A working NVidia driver will get you a working monitor.
The only thing you need now is a working driver which, in the case of NVidia promises to be quite an interesting hunt.
( I ditched NVidia many years ago and what I have left of it are GPUs in some ancient laptops that I have and they are running on Nouveau drivers so I can't help you on your quest in search for the right NVidia drivers for your GPU. My sincere apologies for that)
I really hope someone on this forum with a Geforce GTX 1650 will chime in and help out.
Anyway, good luck on your quest :slight_smile:
Thanks for the great explanation. All is okay now--I have the proper Nvidia driver. Thanks.
