I just installed Ubuntu MATE on my HP ProOne 600 G2, and I'm experiencing screen tearing. The display looks normal again when using nomodeset . I saw the same problem with other distros such as Mint and Opensuse. Can anyone help me?
Hi, @Herry and welcome to the Ubuntu MATE Community!
Hi i don`t know so much to use terminal in linux or fixing bugs i only know the basics like:sudo apt install gdebi,neofetch and remouve so good luck and i am sorry i feel sad for you ![]()
The ProOne 600 G2 uses i915 Gen 9.5 graphics, which is generally well-supported in Linux
Can you post, nicely formatted, the output of inxi -F
Thanks @pavlos_kairis. Here is the output:
System:
Host: UbuntuMate Kernel: 6.11.0-25-generic arch: x86_64 bits: 64
Desktop: MATE v: 1.26.2 Distro: Ubuntu MATE 24.04.2 LTS (Noble Numbat)
Machine:
Type: Desktop System: HP product: HP ProOne 600 G2 21.5-in Non-Touch AiO
v: N/A serial: <superuser required>
Mobo: HP model: 805E v: KBC Version 05.36 serial: <superuser required>
UEFI: HP v: N12 Ver. 02.18 date: 06/05/2017
CPU:
Info: quad core model: Intel Core i5-6500 bits: 64 type: MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 916 min/max: 800/3600 cores: 1: 800 2: 1000 3: 800
4: 1067
Graphics:
Device-1: Intel HD Graphics 530 driver: i915 v: kernel
Device-2: Quanta HP 2.0MP High Definition Webcam driver: uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.11 driver: X: loaded: modesetting
dri: iris gpu: i915 resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa
v: 24.2.8-1ubuntu1~24.04.1 renderer: Mesa Intel HD Graphics 530 (SKL GT2)
Audio:
Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
API: ALSA v: k6.11.0-25-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Network:
Device-1: Intel Ethernet I219-LM driver: e1000e
IF: eno1 state: down mac: 00:25:ab:a8:df:bd
Device-2: D-Link DWA-171 driver: rtw_8821cu type: USB
IF: wlx340a332fa6c4 state: up mac: 34:0a:33:2f:a6:c4
Drives:
Local Storage: total: 465.76 GiB used: 15.36 GiB (3.3%)
ID-1: /dev/sda vendor: HP model: Secure Hard Disk size: 465.76 GiB
Partition:
ID-1: / size: 456.35 GiB used: 15.35 GiB (3.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 1.05 GiB used: 6.1 MiB (0.6%) fs: vfat
dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) file: /swap.img
Sensors:
System Temperatures: cpu: 15.0 C pch: 19.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 8 GiB available: 7.64 GiB used: 1.02 GiB (13.4%)
Processes: 242 Uptime: 3m Shell: Bash inxi: 3.3.34
Thank you @Bombilla.
Find your intel config inside xorg, it might be: /etc/X11/xorg.conf.d/20-intel.conf
Edit and add the TearFree option, save, reboot, test.
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TearFree" "true"
EndSection
Thanks for your suggestion. Unfortunately, it does not work. Let me show this:
cat /var/log/Xorg.0.log | grep -i intel
[ 43.107] (**) | |-->Device "Intel Graphics"
[ 43.767] (II) LoadModule: "intel"
[ 43.767] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 43.858] (II) Module intel: vendor="X.Org Foundation"
[ 43.859] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[ 43.859] (II) intel: Driver for Intel(R) HD Graphics
[ 43.859] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 43.859] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 43.919] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 0
[ 43.919] (II) intel(0): SNA compiled: xserver-xorg-video-intel 2:2.99.917+git20210115-1build1 (Julian Andres Klode <[email protected]>)
[ 43.919] (II) intel(0): SNA compiled for use with valgrind
[ 43.929] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 530
[ 43.929] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[ 43.929] (II) intel(0): Creating default Display subsection in Screen section
[ 43.929] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 43.929] (==) intel(0): RGB weight 888
[ 43.929] (==) intel(0): Default visual is TrueColor
[ 43.929] (**) intel(0): Option "TearFree" "true"
[ 43.930] (II) intel(0): Output eDP1 has no monitor section
[ 43.931] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 43.931] (II) intel(0): Enabled output eDP1
[ 43.931] (II) intel(0): Output DP1 has no monitor section
[ 43.931] (II) intel(0): Enabled output DP1
[ 43.931] (II) intel(0): Output HDMI1 has no monitor section
[ 43.931] (II) intel(0): Enabled output HDMI1
[ 43.931] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 43.931] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 43.931] (II) intel(0): Enabled output VIRTUAL1
[ 43.931] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[ 43.931] (**) intel(0): TearFree enabled
[ 43.931] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 43.931] (==) intel(0): DPI set to (96, 96)
[ 44.021] (II) intel(0): SNA initialized with Skylake (gen9) backend
[ 44.021] (==) intel(0): Backing store enabled
[ 44.021] (==) intel(0): Silken mouse enabled
[ 44.029] (II) intel(0): HW Cursor enabled
[ 44.031] (==) intel(0): DPMS enabled
[ 44.031] (==) intel(0): Display hotplug detection enabled
[ 44.045] (II) intel(0): [DRI2] Setup complete
[ 44.045] (II) intel(0): [DRI2] DRI driver: i965
[ 44.045] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 44.045] (II) intel(0): direct rendering: DRI2 enabled
[ 44.045] (II) intel(0): hardware support for Present enabled
[ 44.607] (II) intel(0): switch to mode [email protected] on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 44.608] (II) intel(0): Setting screen physical size to 508 x 285
[ 45.320] (II) config/udev: Adding input device Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) (/dev/input/event5)
[ 45.320] (**) Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): Applying InputClass "libinput pointer catchall"
[ 45.320] (II) Using input driver 'libinput' for 'Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)'
[ 45.320] (**) Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): always reports core events
[ 45.374] (II) event5 - Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): is tagged by udev as: Mouse
[ 45.374] (II) event5 - Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): device is a pointer
[ 45.374] (II) event5 - Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): device removed
[ 45.401] (II) libinput: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): Step value 0 was provided, libinput Fallback acceleration function is used.
[ 45.401] (II) XINPUT: Adding extended input device "Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)" (type: MOUSE, id 12)
[ 45.401] (**) Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): (accel) selected scheme none/0
[ 45.401] (**) Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): (accel) acceleration factor: 2.000
[ 45.401] (**) Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): (accel) acceleration threshold: 4
[ 45.457] (II) event5 - Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): is tagged by udev as: Mouse
[ 45.458] (II) event5 - Microsoft Microsoft 3-Button Mouse with IntelliEye(TM): device is a pointer
[ 45.461] (II) config/udev: Adding input device Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) (/dev/input/mouse0)
[ 45.463] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event8)
[ 45.464] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event9)
[ 45.466] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event10)
[ 45.467] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event11)
[ 45.469] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event12)
This is a few year old, but may be of some help.
Thanks @GeekBone. It works.
