So when I first installed UM bluetoth autostarted withought a problem . Now It is software blocked . How to fix this ?
Please explain what you mean by “software blocked”!.
Have you checked in Control Centre > Personal > Startup Applications to see if it (bluetooth) is starting with the system?.
Yes the applet is autostarted .
Here is my rfkill list :
indent 0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hp-bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
3: hp-gps: GPS
Soft blocked: yes
Hard blocked: yes
Says bluetooth is soft blocked . Every time I start the system I have to unblock it in rfkill .
I look at the scripts for rfkill in init folder but there is nothing wrong there .
I would say it has something to do with missing firmware?, try the following 2 terminal commands and see if that fixes the problem for you:
Restart after running the above commands if anything updates!.
Nothing broken with packages man . Bluetooth does not autostart thats all . When I enable it with rfkill it works like a charm .
My bad, didn’t read your post correctly, try adding the following command to Control Centre > Personal > Startup Applications:
rfkill unblock all
and see if that fixes the problem!.
This is a work around . I have thought of that . I need a permanent solution .
But I am very gratefull that you took the time to help me . Best regards .
I don’t really have anyting else for you as that is the easiest way I can think of!.
MATE Ubuntu 15.10 on an HP 650 Notebook PC laptop. Bluetooth built in, works. When using USB Bluetooth capabilities, it works.
F12 LED on the button is orange. How can I solve this problem? Thank you very much ! All the best!
I must have messed something in the dconf schemas . After I reset them all . It autostarted normally . Appreciate te help . Tnx .
I don’t get your problem mate. Please be more clear .
2 posts were split to a new topic: Bluetooth not starting on HP650 Notebook
34 posts were merged into an existing topic: Bluetooth not starting on HP650 Notebook
