[solved] Disabling unused laptop display that is set as default
I have a motherboard with a LDVS port and so on install ubuntu always thinks it’s a laptop and sets the default monitor to laptop which of course has nothing attached and leaves me staring at a blank desktop on my hdmi monitor.
In mint I could fiddle with the mouse and get it onscreen and right click and open a terminal and then fire up the display utility and change it but that’s not working here.
So looks like I need to do that in the config file (after booting off a stick). Only all the generic ubuntu posts talk about editing monitor.xml in the .config directory only there is no such file. So how does one do this in mate??
Getting Farther.... from this post I got the lightdm login to appear and got logged in. Edit the 99 file in the subdirectory
now I can right click and get a terminal started.
Now if I knew the display app's commandline name or the settings app I could launch and change it. (in mint cinnamon I knew :0)
Ok,
found it
mate-control-center
To the maintainers: pretty please put the “display settings app” in the desktop context menu in future releases for just this issue.
Can you explain what you mean exactly? Then I suggest, we submit a feature request bug report on https://bugs.launchpad.net/ubuntu-mate.
