Can i replace mate-screensaver to xscreensaver? please let me know thanks.
Hi Jose,
I wouldn’t remove mate-screensaver but there should be nothing to stop you installing and using xscreensaver!.
Yes, you can install xscreensaver. I use it with Ubuntu MATE. I remove MATE screensaver from the startup applications - no need to uninstall it. And of course, you need to be sure xscreensaver is added to the startup applications.
OK, and i did not remove mate-screensaver, so uncheck on start up appilcation, so i hope i did correct, here's picture.
Updated, reboot after that added to starup program, and it worked! thanks!
now i am in love with mate!!!
cheer up!
Please mark as [SOLVED] so it helps others!. Edit the thread topic so it looks like this:
[SOLVED] Replace screen saver
I would edit the command to xscreensaver -no-splash
Otherwise, you may get the little xscreensaver splash screen on login when it starts up.
Be sure to install all the extra screensavers which are extra packages:
xscreensaver-data-extra
xscreensaver-gl
xscreensaver-gl-extra
rss-glx
rss-glx requires some extra steps, and contains some of the best
screensavers. After installing it, read the file
/usr/share/doc/rss-glx/README.xscreensaver to get them to work.
