I am very new to Linux. A friend suggested Ubuntu MATE because my computer is an i5 2nd generation with 4 GBs of RAM. I installed today and am thus far loving the speed of the system. Before installing I had read several tutorials (some a couple of years old). Most said that you should create a minimum of 3 partitions for Linux (/, /home and swap). I attempted to do that but then the installer said I needed a /boot one (with EFI I think?). So I went with the let Ubuntu MATE handle everything.
I installed gparted and then noticed that there was no /home partition but rather a 2.7 TB root directory and a 4 GB swap directory (and a boot directory of 512 MB as boot/efi with flags of boot/esp).
Is a separate /home partition a big bonus or is that more of an outdated theory/practice for linux? I haven’t copied any files from my external HD (which is where I backed my stuff up to before install Ubuntu MATE) so I have no problem at all reinstalling the OS. I really want to get it set up properly the first time and that way I don’t have to worry about stuff later on.
As I said, I am new to linux and some of the tutorials were a couple of years old. I don’t know. Any suggestions would be most appreciated. I am fine leaving it the way it is and also fine with reinstalling.
Thank you in advance for any idea’s/suggestions/etc.
