Hi!
Any ideas?
              Hi, @Heny67
Are you using Ubuntu MATE 24.04 LTS ("Noble Numbat")?  If so, did that "Notes " application ever work correctly for you in that Ubuntu MATE 24.04 version OR did it only work well in previous versions of Ubuntu MATE ?  I ask that because, a few months ago (on September 2024), @marcelo_martin Notes " application ("Sticky Notes ") not working in Ubuntu MATE 24.04 :
    Hello everybody.
Since I've upgraded to 24.04 my notes applet stopped working.
I don't mind if it won't, but I was looking where the data I have is stored so I can recover it.
Couldn't find this info. Does anybody knows where the data is stored?
Thank you.
In a reply that I wrote in that same topic, on 28th September 2024 - "Notes app not working on 24.04 / Data location - #10 by ricmarques
1  -  In a VM (Virtual Machine) running "Ubuntu MATE 24.04  .1 LTS" ("Noble Numbat"), clicking on the "New Note  " menu option of the "Sticky Notes" doesn't work. Indeed, at least in my case, it crashed  with the error message "Sticky Notes" has quit unexpectedly  .
2  - The crash brought the "Sorry, Ubuntu 24.04 has experienced an internal error " window where the "Title " of the crash is revealed to be "stickynotes-applet crashed with SIGSEGV in gtk_text_iter_compare() ":
3  - This may be another case of the following bug that I then found ("Stickynotes crashes on Alpine Linux and Gentoo ") in the "mate-desktop/mate-applets
        opened 01:54PM - 26 Jan 24 UTC
    #### Expected behaviour
`stickynotes-applet` should be able to instantiate stic⦠ky notes in MATE on every popular distro
#### Actual behaviour
on the popular distros Alpine Linux and Gentoo, `stickynotes-applet` launches and creates an icon, but clicking "New Note" does nothing and double-clicking the icon after clicking "New Note" at least once makes an error popup appear
#### Several OS exhibiting expected behavior
- Debian
- Fedora
- Arch Linux
- Ubuntu
#### Steps to reproduce the behaviour on affected distros
How to reproduce the crash:
1. if necessary, recompile mate-applets without using `--disable-stickynotes`
2. right click on a MATE panel->Add to Panel->Sticky Notes->Add->Right click Sticky Notes Icon->New Note->Double click Sticky Notes Icon
How to reproduce the backtrace:
2. compile mate-applets and libX11 with debug symbols and unstripped
3. open a shell and type this:
gdb /usr/libexec/mate-applets/stickynotes-applet
run
4. right click on a MATE panel->Add to Panel->Sticky Notes->Add->Right click Sticky Notes Icon->New Note->Double click Sticky Notes Icon
5. Type this in the shell:
bt
<details><summary>stdout, stderr and backtrace</summary>
<p>
GNU gdb (Gentoo 13.2 vanilla) 13.2
Copyright (C) 2023 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://bugs.gentoo.org/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/libexec/mate-applets/stickynotes-applet...
(gdb) run
Starting program: /usr/libexec/mate-applets/stickynotes-applet
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
[New Thread 0x7ffff36c56c0 (LWP 1507161)]
[New Thread 0x7fffebfff6c0 (LWP 1507162)]
[New Thread 0x7ffff2ec46c0 (LWP 1507163)]
[New Thread 0x7ffff26616c0 (LWP 1507164)]
[New Thread 0x7ffff1d816c0 (LWP 1507168)]
[New Thread 0x7ffff0fff6c0 (LWP 1507169)]
[Thread 0x7ffff0fff6c0 (LWP 1507169) exited]
[New Thread 0x7ffff0fff6c0 (LWP 1507170)]
[New Thread 0x7fffeb7fe6c0 (LWP 1507171)]
[Thread 0x7ffff0fff6c0 (LWP 1507170) exited]
[Thread 0x7fffeb7fe6c0 (LWP 1507171) exited]
[New Thread 0x7fffeb7fe6c0 (LWP 1507172)]
[New Thread 0x7ffff0fff6c0 (LWP 1507173)]
[Thread 0x7fffeb7fe6c0 (LWP 1507172) exited]
[Thread 0x7ffff0fff6c0 (LWP 1507173) exited]
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_window_set_screen: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_window_set_decorated: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_window_set_skip_taskbar_hint: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_window_set_skip_pager_hint: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_add_events: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_text_view_get_buffer: assertion 'GTK_IS_TEXT_VIEW (text_view)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_set_direction: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_window_stick: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_window_resize: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_image_set_from_icon_name: assertion 'GTK_IS_IMAGE (image)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_image_set_pixel_size: assertion 'GTK_IS_IMAGE (image)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_show: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_window_set_title: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_label_set_text: assertion 'GTK_IS_LABEL (label)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_override_background_color: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_override_color: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_override_font: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_text_view_set_editable: assertion 'GTK_IS_TEXT_VIEW (text_view)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_text_view_set_cursor_visible: assertion 'GTK_IS_TEXT_VIEW (text_view)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_set_tooltip_text: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_check_menu_item_set_active: assertion 'GTK_IS_CHECK_MENU_ITEM (check_menu_item)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.306: gtk_widget_realize: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): GLib-GObject-CRITICAL **: 19:02:18.306: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(stickynotes-applet:1507158): GLib-GObject-CRITICAL **: 19:02:18.306: invalid (NULL) pointer instance
(stickynotes-applet:1507158): GLib-GObject-CRITICAL **: 19:02:18.306: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(stickynotes-applet:1507158): GLib-GObject-CRITICAL **: 19:02:18.307: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(stickynotes-applet:1507158): GLib-GObject-CRITICAL **: 19:02:18.307: invalid (NULL) pointer instance
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.307: gtk_text_view_get_buffer: assertion 'GTK_IS_TEXT_VIEW (text_view)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.307: gtk_window_present_with_time: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:18.307: gtk_window_stick: assertion 'GTK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gtk-CRITICAL **: 19:02:20.483: gtk_widget_get_window: assertion 'GTK_IS_WIDGET (widget)' failed
(stickynotes-applet:1507158): Gdk-CRITICAL **: 19:02:20.483: gdk_window_get_display: assertion 'GDK_IS_WINDOW (window)' failed
(stickynotes-applet:1507158): Gdk-CRITICAL **: 19:02:20.483: gdk_x11_display_get_xdisplay: assertion 'GDK_IS_DISPLAY (display)' failed
(stickynotes-applet:1507158): Gdk-CRITICAL **: 19:02:20.483: gdk_x11_get_xatom_by_name_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
(stickynotes-applet:1507158): Gdk-CRITICAL **: 19:02:20.483: gdk_x11_window_get_xid: assertion 'GDK_IS_X11_WINDOW (window)' failed
Thread 1 "stickynotes-app" received signal SIGSEGV, Segmentation fault.
0x00007ffff6e9744e in XChangeProperty (dpy=dpy@entry=0x0, w=0, property=property@entry=0, type=type@entry=6,
    format=format@entry=32, mode=mode@entry=0, data=0x7fffffffd140 "\233\002", nelements=4)
    at /var/tmp/portage/x11-libs/libX11-1.8.7/work/libX11-1.8.7/src/ChProp.c:46
46	/var/tmp/portage/x11-libs/libX11-1.8.7/work/libX11-1.8.7/src/ChProp.c: No such file or directory.
(gdb) bt
#0  0x00007ffff6e9744e in XChangeProperty
    (dpy=dpy@entry=0x0, w=0, property=property@entry=0, type=type@entry=6, format=format@entry=32, mode=mode@entry=0, data=0x7fffffffd140 "\233\002", nelements=4) at /var/tmp/portage/x11-libs/libX11-1.8.7/work/libX11-1.8.7/src/ChProp.c:46
#1  0x000055555555bba4 in set_icon_geometry
    (height=<optimized out>, width=<optimized out>, y=<optimized out>, x=<optimized out>, window=0x0) at stickynotes.c:63
#2  stickynote_set_visible (note=0x5555555eb170, visible=<optimized out>) at stickynotes.c:749
#3  0x000055555555de1a in stickynote_show_notes (visible=0) at stickynotes_applet_callbacks.c:74
#4  stickynote_toggle_notes_visible () at stickynotes_applet_callbacks.c:81
#5  applet_button_cb (widget=<optimized out>, event=<optimized out>, applet=<optimized out>)
    at stickynotes_applet_callbacks.c:95
#6  0x00007ffff768fbf6 in  () at /usr/lib64/libgtk-3.so.0
#7  0x00007ffff7283630 in g_closure_invoke () at /usr/lib64/libgobject-2.0.so.0
#8  0x00007ffff7296bbf in  () at /usr/lib64/libgobject-2.0.so.0
#9  0x00007ffff7297fa9 in  () at /usr/lib64/libgobject-2.0.so.0
#10 0x00007ffff729e242 in g_signal_emit_valist () at /usr/lib64/libgobject-2.0.so.0
#11 0x00007ffff729e2f7 in g_signal_emit () at /usr/lib64/libgobject-2.0.so.0
#12 0x00007ffff794a4ac in  () at /usr/lib64/libgtk-3.so.0
#13 0x00007ffff77fb64e in  () at /usr/lib64/libgtk-3.so.0
#14 0x00007ffff77fd246 in gtk_main_do_event () at /usr/lib64/libgtk-3.so.0
#15 0x00007ffff7ecbc35 in  () at /usr/lib64/libgdk-3.so.0
#16 0x00007ffff7efd592 in  () at /usr/lib64/libgdk-3.so.0
#17 0x00007ffff717dc02 in  () at /usr/lib64/libglib-2.0.so.0
#18 0x00007ffff7180db7 in  () at /usr/lib64/libglib-2.0.so.0
#19 0x00007ffff718169f in g_main_loop_run () at /usr/lib64/libglib-2.0.so.0
#20 0x00007ffff77fc42d in gtk_main () at /usr/lib64/libgtk-3.so.0
#21 0x00007ffff7fa30f1 in  () at /usr/lib64/libmate-panel-applet-4.so.1
#22 0x0000555555559ec5 in main (argc=<optimized out>, argv=<optimized out>) at stickynotes_applet.c:87
</p>
</details>
#### MATE general version
1.26.1
1.27.1
#### Package version
mate-applets-1.26.1-r3 (Alpine Linux)
mate-applets-1.26.1 (Gentoo)
mate-applets-1.26.1-r2 (Gentoo)
mate-applets-1.27.1 (Gentoo)
C libraries:
musl-1.2.4_git20230717-r4 (Alpine Linux)
glibc-2.38-r9 (Gentoo)
#### Linux Distribution
#### Link to bugreport of your Distribution (requirement)
https://bugs.gentoo.org/922937
https://gitlab.alpinelinux.org/alpine/aports/-/issues/15719
Here's the link to that reply of mine in that other topic, here in the "Ubuntu MATE Community":
    Hi, @marcelo_martin
I hope this helps, at least somewhat
              Thanks for the answer! I have not used the program until now, only now I wanted to.
