A couple of days ago I received an update for the Tor Browser. Ever since that time I am unable to start it, nothing happens. I have removed it and reinstalled from the boutique but still NG.
Hi
Do you get an error message when running it from the terminal?
tor-browser-en.sh
Hi Don
I just installed it in 16.04.2 using the boutique and it boots up just fine.
Try booting it in terminal and see if it gives any errors.
tor-browser-en.sh
Touche ouroumov touche
Here are the results:
cp: cannot stat ‘/home/don/.tor-browser-en/INSTALL/Browser/TorBrowser/Data/Browser/profile.default/search.json’: No such file or directory
Run this command once:
touch ~/.tor-browser-en/INSTALL/Browser/TorBrowser/Data/Browser/profile.default/search.json
I ran the command and then ran Tor Browser. All OK. That command fixed it, Thanks
I’ve now added this to the list of common problems affecting Xenial.
