Transparent Login Box
HI!
does anyone know how to make the login box transparent, if at all possible?
I was thinking of something along the lines of the Ubuntu login screen.
Sadly, I don’t think it’s possible. The LightDM GTK+ Greeter login box is a dialog box but without the window borders.
It might be possible to install the Ubuntu login screen (unity-greeter), but I wouldn’t advise doing so due to needing a lot of dependencies which could break something later.
Thanks, I thought as much. I did look at installing the Unity Greeter but decided it was probably too much work for me, not that confident and don’t want to break anything as you say.
Although, in 3 simple steps, you can install Unity Greeter quite easily:
