Thank you for this hint as well
I switched back and forth from these two options that were proposed by olek and your link:
- using the classic clock applet
- modifying the new clock format
I managed to apply a custom format to both of them!
But, there is a slight advantage of the classic clock, which is why I switched back to using it:
within custom formats it is possible to use html declarations to make some parts smaller! This was the ultimate solution for me in the past, so I will use it again.
Sadly the configure locations changed, so it took some times to find them out:
Apply custom formats to clock applets
Everything below has to be done in dconf-editor
New clock (in complete notification applet)
- Open
dconf-editor
- Go to:
/com/canonical/indicator/datetime/
- Enter your custom format in
custom-time-format
- Change
time-format
to the value custom
Voilà, your custom format should have been applied!
Classic clock applet
- Add "Clock" to mate panel
- Open
dconf-editor
- Go to:
/org/mate/panel/objects/
- Go through all
object-X
entries, until you find one that has the applet-iid=ClockAppletFactory::ClockApplet
- Go down to the
prefs
folder
custom-format
- Change
format
to the string custom
My absolute overruler custom format
<small>%A, %Y-</small>%m-<b>%d</b> %T, <small>KW%V</small>
Looks like this: Sunday, 2020-06-07 22:58:00, KW23
Links:
