I've flashed 15.10 to my USB stick and ran it without installing. The very first problem I encountered was that some characters were displayed incorrectly and the resolution was very low (1024x768 compared to 1920x1080, my native res), and the monitor is labeled as unknown.
For the characters issue, another user found that installing the proprietary drivers fixed it for them, but NVIDIA drivers can only be installed properly on an installed system.
open a terminal (Ctrl + Alt + t) and paste the following command in it (it may fail if the package is already installed, just continue to the next command!):
sudo apt-get install pppoeconf
Then run:
sudo pppoeconf
and follow the instructions that follow, you will need your internet provider username and password that they gave you!.
Go here: Ubuntu – Error then download and save the .deb package, transfer it to your PC via USB stick and install it using Gdebi (right click > Open with).
When you manually set up your connection, in case you don't know, your username and the name of your ISP make up the PPPOE username, it will look something like the following:
The above command should work with CD, DVD or USB stick, I think. Although I have not tried it with a stick. Give it a try, worst that can happen is it will not work.
Somewhere out there is a list of all packages thats contained on the live installer. I have seen it, but I sure can’t find it
Tried the Gdebi and USB stick method and no results so far. What’s interesting is that on 15.04 my PPPoe did work with terminal (but not with the tray icon) and the only problem was the graphics(it didn’t detect my 1920x1080).
I used Gdebi to install that deb package… All good, it installed the package but the connection didn’t work. Tried a second time, removing the package and installing it again, same thing, no connection.
what type of modem (or router) do you have?, please tell us the model and make and also; what ISP are you using?, you might be able to access the modem/router and enter your details directly into it without the need for PPPoE!.
Provide us with those details and we might be able to get you up and running.
I’m from Romania and my ISP is RCS&RDS. I don’t have any router, the internet cable is plugged directly into my PC, and I’m 100% sure that my PPPoE username and password are correct.
I have a Vodafone (Kabel Deutschland) connection, I don’t have a router as such and just plug my network cable into my Telephone/TV/Network device, I cannot say how your system works as I don’t speak Romanian!.
