http://cdimage.ubuntu.com/ubuntu-mate/daily-live/current/
So i install guest additions and rebooted to this...twice
Solved by removing Tilda from startup,but getting panel crash apport.
That Tilda interference I got a couple of times during the 16.04 cycle. I thought about removing it, but it does come in handy. Its a interesting program that I discovered by accident. I like it so much that I put it on one of my Xubuntu installs.
Now that Iβve used it for some time, I notice under System Monitor. If you click Memory, Tilda is the biggest hog. At least on my system. Around 60megs.
Well not too bad of a start. I also notice that my pointer is off center, when I click on something I donβt always hit it.
Compiz is stable, but windows cannot be switched to another workspace.
A post was split to a new topic: Using the Tilda Terminal
