Hi. I have the exact same situation. I have toggled the check for new versions to each option. Restarted in between and I am still not receiving an option to upgrade.
I also follwed all options described in the blog post to no avail. This is from a clean install of 19.04 then fully updated. This is on a Thinkpad T480.
I ended up just installing from scratch with the ISO. I use this laptop as mostly a test machine anyway (thus putting a beta 1 on it ) but others may not want to reinstall from scratch.
Thanks. I will try that. However, the project may want to look into this further if there is some condition that can/will interfere with the ability to upgrade - because everybody deserves the great improvements in 19.10!
and it worked. Did you add the "-d" for the development release? I was having the same problem as you following the instructions at the bottom of the 19.10 release notes page
So far everything works except edge scrolling on my touchpad. Switched to 2-finger scrolling as a workaround.
Thanks for this advice; mine is in the process of upgrading so I have to go. Haha.
I think I misunderstood the release notes; these are essentially the 'production' release notes issued early. So the upgrade instruction from release 19.04 are there, but that really represents the situation when 19.10 releases not now.
I've never seen the buttons next to the tabs like that, is that a Firefox setting or a MATE setting? Are you using marco or Compiz or something else? What theme is it? Are you on a regular density screen or HiDPI?
Could you try different themes and see if it still happens? Also, try moving the buttons to the right side and see if it also happens there.
Sorry for all the questions, I'm trying to figure out whether this is the theme's fault, marco's fault, or Firefox's fault
So after trying it out live I went ahead and upgraded my new desktop (more on that another time) to 19.10 beta from 19.04 although it took all night (thanks to our super slow internet) it worked fine, panel switching is indeed greatly improved, the only issue I got was occasionally after tweaking the Mutiny layout, but not saving the modifications, when one switched to something else (the netbook layout was the major one that caused issues) and back, Mutiny wasn't quite right, but after switching to a couple other layouts and back it was, but that doesn't bother me because I don't use Mutiny anyways I was just trying it out, I love the new indicators and have been wanting them for a while, I even used the date time indicator before on 18.04, even though it pulled in a boatload of dependencies, this really is one of the best releases in a while, I love Gnome MPV and Evolution, and have used both before and imo are far better choices, one thing I would like to see would be an Adaption of the Yaru theme in green for MATE soon, and not for MATE, but I would like to see Evolution's setup process a bit easier, but otherwise this is a great release, also I'm not super enamored with any of the menus but I hope to change that soon
edit: the Bluetooth indicator just disappeared not sure why, but it crashed I don't use Bluetooth much anyways so not a huge problem but it did
Thanks for the tip regarding -d option, I use command in the past without knowing what it really do, just because it was mention on beta releases, and just copy paste it was easy than typing the command in terminal, and forgot about it... shame on me as I use Linux for quite some time
So proceeding to upgrade right no on one laptop, and when time on all my PC...
Installing VirtualBox using Oracle ppa is not available for 19.10, but when I try to install it using the one from Ubuntu get the following error, I use kernel 5.3.0-16
vboxdrv.ko:
Running module version sanity check.
modinfo: ERROR: missing module or filename.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/5.3.0-16-generic/updates/dkms/
vboxnetadp.ko:
- Original module
- Installation
vboxnetflt.ko:
- Original module
- Installation
vboxpci.ko:
- Original module
- Installation
depmod.........
DKMS: install completed.
Ok, I didn't realize this was CSD. Those are not drawn by marco. The issue then must be either on Firefox or GTK. The themes have a CSS file that could be modified to compensate for that.
I'm assuming this doesn't happen with other themes, right?
Actually it will happen with all gtk 3 themes that support csd, it's a setting in firefox that needs changed, I believe Firefox switched to csd as a default instead of as an option, although there is an option to disable it
When I use the multiple desktop applet in the deskbar (top bar) and I switch to desk 2.3 or 4 the deskbar vanishes and I can't even get back to my first screen - except for when I have a process running on my first screen that is displayed in the dock applet which I have in the side bar (Mutiny layout) - otherwise I'm stuck.
Any ideas for a workaround?
Also the weather app doesn't have the option to access my town like most other weather apps do - can that be changed or improved?
The time app in the deskbar doesn't display the date in numbers - can that be changed or is ther a workaround for that?
