It's the exact same problem I'm having (I did post a video too)
Hi again, @Ygor6889.
OK. I suggest that we try now something different: let's try to use the "apport-cli" command / tool to extract the several parts of the ".crash" file into several files.
If you can open a "MATE Terminal" window (without the "auto ending session" issue also happening by doing that), I suggest that you try the following commands (I'm assuming here that your "Home" directory is "/home/ygor"). Also, in case you don't already know, the '$' ("dollar sign") in the following commands is just representing the shell prompt (don't type that dollar sign in your commands):
$ mkdir /home/ygor/mycrash
$ cp -piv /var/crash/_usr_lib_xorg_Xorg.0.crash /home/ygor/mycrash
$ cd /home/ygor/mycrash
$ apport-cli _usr_lib_xorg_Xorg.0.crash mycrash-files/
It's possible, when you do that last "apport-cli" command, that you get an error like the following one (but don't worry about that);
File "/usr/bin/apport-unpack", line 77, in <module>
pr.extract_keys(f, bin_keys, dir)
File "/usr/lib/python3/dist-packages/problem_report.py", line 269, in extract_keys
raise ValueError('%s has no binary content' %
ValueError: ['separator'] has no binary content
(It's also possible that you get an "apport-unpack" crash during this process, but also don't worry about that).
Now you should have a "mycrash-files" folder with lots of files. You can see the list of those files by entering a command like the following:
$ ls -l /home/ygor/mycrash/mycrash-files/*
Now, I would like to ask you to publish a new message here in this same topic with the content of the "Title" file by entering the output of the following command:
$ cat /home/ygor/mycrash/mycrash-files/Title
References for this answer of mine:
... particularly the following great answer written by @Norbert_X in that same Question in the "Ask Ubuntu" web site:
I can't run "cd /home/ygor6889/mycrash" because of the auto ending session
@Ygor6889, Igor, is your video card also from intel? I just solved the problem on the Latitude E6410. I created the /etc/X11/xorg.conf.d/20-intel.conf file with the following content:
$ cat /etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TearFree" "true"
EndSection
Then I restarted the system and Ubuntu Mate stopped crashing!
I saw someone on this post reporting a similar problem:
And then I followed what was in the 6.1 section of the ArchLinux Wiki:
https://wiki.archlinux.org/title/intel_graphics#Tearing
Yes my video card is a Intel HD Graphics
I'm gonna try that, if it works im gonna be super happy
OMG IT DID WORK, Obrigado!
I wasted a whole week trying to fix this, you saved me
Thank you to everyone who tried to help me, @esan_br gave the solution, not only it did work but it completed fixed the issue
Problem SOLVED!
"Obrigado!"
This works for me too, thanks Elias!. Intel G41 driver on old desktop pc, works ok with 20.04 but 22.04 continuously crashes (even with a fresh install) and your post resolves the problem.
