Recently in helping a friend with his PC I installed Ubuntu Mate for him.
All went well - except that his USB3 ports didn't work - but everything else does & he has no need for USB3, so no biggie.
Now the shoe is on the other foot because I'm making a PC up for my own uses now & this USB mess is even stranger - the USB3 ports work, but none of the USB2 ports do ?!?
Being the curious sort I've tried using the USB2 ports for live booting & whenever it is an Ubuntu variant - it works for a time, then pauses or halts with the message:
"(initrams)Unable to find a medium containing a live file system"
Doing the same with the USB3 ports Ubuntu variants boot fine.
Moving right along, I tried several other live booting sticks (Partition Wizard, etc.) & they all boot 100% fine using the USB2 ports.
Searching here for related threads yielded only these that I could find:
I hope some folks here have a clue what may be out of kilter & how I may fix this ?!?
The PC is recently built with all new parts, so hopefully this is fixable via software, somehow.
Dave_Barnes you are amazing - sincerest thanks !!!
Both are working now.
I also did another test by enabling the IOMMU setting & that caused the opposite response - so USB2 worked & 3 did not.
What concerns me presently is that I will be using windows in a VM on my new CPU, and I will be attaching physical HDD partitions to my VM - so when I read here:
And here:
That it may be important to have enabled, well - now I am again concerned & wonder if this is the only solution ??
If anyone can further educate me about IOMMU I will hugely appreciate the help !!
