Amidst everyone else, I've got to host a web meeting. My webcam used to work--at least in Facebook messenger. It no longer works there or anywhere. (I have installed some things like java since then.)
I have to get it to work in Webex. Any ideas? I've tried Cheese and it comes up, but the buttons at the bottom where the video icon sits are grayed out. When I try Webex, a light comes on my lap top near the camera for a few seconds like it is trying to access the camera. Then, nothing.
I am using Ubuntu Mate 18.04.
You guys have helped me in the past. So, I feel confident you can again. Thanks!
This is what I got. Does not appear to be any webcam.
Bus 002 Device 006: ID 04f9:0229 Brother Industries, Ltd
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0bda:5801 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I've not yet rebooted because this is what I got with the last 2 command lines. Should I continue to reboot?
root@Martha:/home/lisa# wget -q http://packages.ucview.com/public.gpg -O- | sudo apt-key add -
OK
root@Martha:/home/lisa# sudo apt-get update
E: Malformed entry 49 in list file /etc/apt/sources.list (URI parse)
E: The list of sources could not be read.
root@Martha:/home/lisa# sudo apt-get install ucview
After the restart, my computer will not boot up. It is stuck in a boot mode. It does not even get to the GRUB line. So, is there a boot up download I can get somewhere to get to the command line? Then how do I fix it? I saw somewhere that it could be related to graphics?
