Weird Scrolling Artifacts
Hello everyone!
I have this bug on two machines with Ubuntu Mate. It is hard to explain, which explains why I couldn't find anything about it on Google. Here is the bug with the (awesome) Welcome application, but it appears in multiple apps. (e.g. Rythmbox)
Short Video:
https://youtu.be/TaEZnbms-qI
Does anybody know a fix for this?
it might be related to your graphics card drivers, do you have any installed on your PC's?:
Have you done a full system update?:
Thanks for the answer.
I tried both the proprietary and the open source nvidia drivers and I’m pretty certain they were the right version (nvidia-304 and nvidia-340 for a GTX 660). The system is also up to date.
Hmm, that “overflow” animation when it reaches the end of scrolling seems to just be a white box. I bet it’s due to that theme (forgot the name!).
Please try a different theme to check. :slight_smile:
I’m no GTK or theme expert, but it should be possible somewhere to copy over the missing graphic from another theme - like Ambiant-MATE… but I’m not sure where! :thinking:
The theming was the issue, thanks! I was using the Yuyo-Dark theme and I guess that animation is not properly implemented. Now to look for a fix :smiley:
EDIT:
Fix: http://unix.stackexchange.com/questions/250880/how-to-disable-or-fix-gtk-scrolling-indicators
Sadly the problem is still present, if the window is unfocused.
EDIT 2:
To fix that you have to change
.undershoot {
    background: none;
to
.undershoot.top {
    background: none;
.undershoot.bottom {
    background: none;
.undershoot.left {
    background: none;
.undershoot.right {
    background: none;
