Welcome and Boutique Daily Builds
Welcome and Software Boutique will be undergoing a fair amount of improvements in the Artsy (17.10) cycle, including the introduction of a dedicated Software Boutique, and unifying the version across 16.04, 16.10 and 17.04.
This is your ticket to be on-board for test driving the latest changes, even if you’re not running 17.10.
What are daily builds?
  • These are development versions built straight from the code repository within 24 hours of new changes being committed.
  • A chance for testers and early birds to check out the latest changes before they go stable.
  • Builds are automatically generated no more then once a day.
  • Bugs and broken features are inevitable.
Opt in!
This will update your current version in-place. Builds are the same and available across:
  • 16.04 - Xenial
  • 16.10 - Yakkety
  • 17.04 - Zesty
  • 17.10 - Artful
sudo add-apt-repository ppa:ubuntu-mate-dev/welcome-daily
sudo apt update
sudo apt upgrade ubuntu-mate-welcome
To downgrade, simply remove the daily PPA and re-install Welcome.
Both the Welcome “stable” and Welcome “daily” PPA can co-exist, but the daily PPA will naturally contain a higher version.
Changelog
See the commit log to get an idea of the changes that have happened.
Where to report bugs
You can report reproducible bugs on:
If it’s a problem with Boutique software (e.g. Antiviral and the infinite Caja bug), please use the #development-discussion category on this forum with #boutique tag. With enough feedback, software can be pulled out in these instances. Note that for development versions of Ubuntu MATE, this will be expected.
Is it intended that the daily build shows 16.04.2 as “Unsupported Distribution”?
Either ubuntu-mate-desktop or ubuntu-mate-core isn’t installed on your computer – it’s how Boutique determines whether the user is actually using Ubuntu MATE or another distribution.
ubuntu-mate-desktop was missing, thanks.
Maybe there is a better way? ubuntu-mate-desktop has lots of dependencies and just a small tweak to the system will remove it. ubuntu-mate-core might not have as many dependencies, but it recently got removed when I un-installed the unattended-upgrades package.
Anyway, I have not opted for Welcome daily builds. And despite these two meta-packages not being present on my system it shows "Ubuntu 16.04.2 LTS" in Welcome. I'm happy it says "Ubuntu 16.04.2 LTS" instead of "Unsupported Distribution" because that sounds a lot more worrying.
The only reason these meta-packages exist is for distro-upgrades, so maybe create a separate "identifier-package" which can come preinstalled in Ubuntu MATE and doesn't have any dependencies. I don't know much about this, but those meta-packages tend to disappear quicker than quick.
I'm using UM 16.04 now after getting rid of Network Manager (wicd instead) and installing Compiz Reloaded. It was a rocky road, but I'm happy here.
Nevertheless I would suggest not making UM Welcome/Boutique too Ubuntu MATE specific. Anything Ubuntu-based should be able to take advantage of this work I think. Just make sure you stay in control over decision-making/development. No need for big changes as I see it, it's already a great application. :+1:
FWIW, after 16.04 (so 16.10 and 17.04), the meta-packages use recommends instead of depends, so they are not removed if you uninstall built-in apps. I’ve removed all sorts of things in 16.10, like Libreoffice and Thunderbird, and the meta-package stayed put.
