I installed Wine on my Dell laptop. I had no issues. I then used the same method to install Wine to my Desktop. I did not receive any errors during the installation process and Wine is installed. However, when I run “winecfg” I get the following errors:
$ winecfg
000d:err:wincodecs:PngEncoder_CreateInstance Failed writing PNG because unable to find libpng12.so.0
000d:fixme:ole:CoCreateInstanceEx no instance created for interface {00000103-a8f2-4877-ba0a-fd2b6645fb94} of class {27949969-876a-41d7-9447-568f6a35a4dc}, hres is 0x80004005
000d:err:menubuilder:convert_to_native_icon error 0x80004005 creating bitmap encoder
After the error list, I do get the winecfg menu. I suspect the error has something to do with adding architecture i386. When I first ran “sudo dpkg --add-architecture i386” on my laptop, the installation took some time with many command lines listed. When I first ran this command on my desktop, the system instantly returned me to the terminal prompt. Nothing seemed to be installed. Any suggestions how to approach this issue?
