Evening all,
My normally functioning UM laptop has effectively bricked itself after the updates from earlier this week were installed. Perhaps "bricked" is a little dramatic but read on. I am stuck.
Laptop: ACER Aspire F5-571 (v1.31 system BIOS), secure boot disabled and UEFI made enabled.
Issue: Updated today and it needed a reboot. Once I rebooted the following messages are received on bootup.
"Failed to open \EFI\Microsoft\Boot\grubx64.efi - Not Found
Failed to load image \EFI\Microsoft\Boot\grubx64.efi: Not Found
start_image() returned not found
System Bootorder not found initialising defaults
Creating boot entry "boott003D" with label "ubuntu" for file \EFI\ubuntu\shlmx64.efi
Reset System"
Then the laptop reboots, repeating the above in a loop.
Lots of searching online, even using rescatux does not change anything. Rescatux tells me it repairs the grub and windowns UEFI files but not change. The only time I made a change is manually copying over the grubx64.efi file from the EFI...ubuntu\Boot directory to the EFI...Microsoft\Boot directory, and in this case a @no bootable media@ message results. I can of course boot using the CDROM.
I do not dual book, only ubunti on the system although there are 2 partitions, sda1 (EFI, Fat32, boot) and sdb1 (1TB main partition with OS)
I would normally just blow the disk (format) and start again but there is 1 file not backed up in my home directory, which is encrypted (ecryptfs) that I need. I cannot seem to be able to ecryptfs-recover-private as "permission denied". Hence wanting to get in, get the file, then I'll start again.
It looks like somehow UEFI has been screwed up totally. Googling and trying the various suggestions has produced no results.
Any help/suggestions very welcome indeed. stuck now.
Thanks
Andy
