Hi guys, I seem to remember hearing @Wimpy say on a podcast somewhere that he’s currently evaluating app launchers to be included out of the box with Ubuntu Mate. Any updates on the decision? Is there a list of the possible candidates?
This interests me because I can’t use a desktop without an app launcher. As a matter of fact, I don’t just launch apps, but I also do quick math calculations and I also depend on my launcher to find and open documents / pictures by name. I also expect it to learn from my usage patterns and make my apps and/or docs be suggested first in the list based on the frequency of usage.
Thanks! Interesting to hear that it’s working for you. Is it “intelligent” in the sense that it learns from your usage habits and starts suggesting your most used apps and files first as you type just a few letters?
Ridiculously large amount of -dev package deps results in hundreds of MB installation
Intelligently places most used results on top
Doesn’t merge application and file results in the same view
I can’t find a way to make it open the parent folder of a file
Doesn’t seem to find folder names
Gnome Shell
Only usable inside Gnome Shell, which I don’t like
Built in search is fairly fast
Does not intelligently place most used results on top
randomly can not find certain files
No “open parent folder” option
Krunner
Requires a large amount of KDE deps, and I don’t run KDE
Doesn’t have an “open parent folder” option for files
Unity
Basically requires running Ubuntu with the Unity desktop
Very slow search, even on a very fast system
Frequently doesn’t return results without searching, backspacing, and re-typing
Useful thumbnails of results
Very buggy calculator functionality doesn’t usually work without specifically clicking on the calculator source, defeating the purpose of using it for a quick calculation
So I’m not too thrilled with any of these options. I’m currently using Synapse. Albert is looking really good now with its 0.7.x release.
Are there any other options I’m not yet aware of? And what are you using?
Cool, thanks a lot @Wimpy! Did you file a bug report about the Files plugin segfaulting? On Manjaro (Arch) it works perfectly for me with over 20,000 files indexed.
Kupfer is the best when it comes to integration with gnome desktop. However it is not maintained well any more. So I think synapse could be installed as default.
Now that I think of it Kupfer is far better. A recent updated version has been pushed to the ppa. Can we make this default? The problem with synapse is it’s doesn’t work IBUS is disabled (keyboard input method).
It would also be great if Ubuntu mate team willing to work on it. Few things still needs to updated. Thanks.
@Cold All the plugins you talked about are available in kupfer. Recently python3 port has happened and it is more active than ever. Here are the list of few other plugins I use in kupfer:
SSH host (search ssh host and connect to it)
Top (send any signal like kill or abort to any running process)
Remmina
Thunderbird (search mail etc)
Contacts (search and open calendar events in Gnome Contacts)
